if($ru){ ?> } else{ ?> } ?>
Building Maintenance Engineer - Electrical Bias Location: Canary Wharf Hours of Work: 7am to 7pm 4 on 4 off Salay...: £49,000 + Shift Allowance Apt Talent are currently working with a key client on a new requirement for a Building Maintenance...
About Role The multi-skilled, electrical biased role is key to delivering reliable maintenance and reactive... Multi-skilled Electrical Engineers split shift roles are all permanent posts working between 7am-7pm full time 40 hours...
as a single operative undertaking planned preventative maintenance (PPM) and repair of mechanical and electrical equipment..., and building fabric within a retail property environment. KEY RESPONSIBILITIES To carry out planned and reactive maintenance...
Maintenance Electrician Experience in electrical maintenance within building services or facilities 18th Edition qualification... for Callout Shift – Days (Mon–Fri 8:00am – 4:00pm + 1 in 4 on-call rota) Job Role of the Maintenance Electrician A fantastic...
and Rectification: Identify and rectify faults within the building maintenance scope, guaranteeing operational efficiency and minimizing... activities to the Building Maintenance Team Manager for resolution. Package Description Salary & Hours £44,311.54 per annum...
building maintenance scope, guaranteeing operational efficiency and minimizing downtime. Repair and Work Requests Handling... or problems encountered during planned or unplanned maintenance activities to the Building Maintenance Team Manager for resolution...
Operator - Building Engineer (HVAC) is responsible for the safe and efficient operation, installation, maintenance, and repair... of luxury excellence. Job Description Reporting to the Director, Engineering & Facility Operations, the Shift Building...
as our new Shift Building Operator - Plant Engineer. Reporting to the Director, Engineering & Facility Operations, the Shift... Building Operator – Plant Engineer is responsible for the safe and efficient operation, monitoring, and maintenance of the...
of a multi-skilled engineering team. Accountabilities: Mechanical and Electrical maintenance, including Carry out planned... and reactive electrical and mechanical maintenance across the ASRS system Diagnose and resolve complex electrical and mechanical...
Role We're looking for a proactive and versatile Maintenance Engineer with strong electrical expertise and sound... downtime. As a Multi-Skilled Engineer you will: Carry out planned preventative maintenance (PPM) and reactive maintenance...
