Country: Machine Setter
Java /Java /Senior Full Stack Engineer jobb - Nyajobben.se - Jobb sök
Vart är du på väg?
Lediga Java /Java /Senior Full Stack Engineer jobb
Senior Software Engineer, Full-Stack Applications (Java)
Senior Software Engineer, Full-Stack Applications - AI Fluent Fitch Ratings is seeking a Senior Software Engineer... vision and accelerate AI-enabled transformation - Design robust, scalable full-stack applications using Python and React...
Företag: Fitch Group
Stad: London
Datum: 12 Nov 2026
Sida:
Sök jobbet här
Senior Agentic AI Full-Stack Software Engineer (Java & React / Javascript / Angular / Claude Code / Codex)
Senior Agentic AI Full-Stack Software Engineer (Java & React / JavaScript / Angular / Claude Code / Codex.... About the role: As a Senior II Software Engineer, you will build capabilities to support scientific researchers through the...
Företag: Elsevier
Stad: Oxford
Datum: 30 Sep 2026
Sida:
Sök jobbet här
Företag: RELX
Stad: Oxford
Datum: 30 Sep 2026
Sida:
Sök jobbet här
Senior Full Stack Java Engineer
Project description As a Senior Full Stack Java Engineer within the US Corporate Loans POD, you will design, develop... within Financial Services. Strong expertise in Java, Spring Boot, REST APIs, and distributed systems. Experience with Kafka, IBM MQ...
Företag: Luxoft
Stad: London
Datum: 12 Sep 2026
Sida:
Sök jobbet här
Senior Java Full Stack Developer
software development lifecycle. Full-Stack Awareness & End-to-End Ownership While heavily focused on backend architecture... and data systems, provide architectural oversight across the full application stack, collaborating effectively with frontend...
Företag: Citigroup
Stad: Belfast
Datum: 07 Nov 2026
Sida:
Sök jobbet här
Lead Software Engineer - Java Full Stack
for an experienced Software Engineering Leader to join JPMorgan Chase. As a Lead Software Engineer within Asset & Wealth Management... platform used by Risk managers and senior leadership across the firm. You will partner closely with Product, Risk, Data...
Företag: JPMorgan Chase
Stad: London
Datum: 05 Sep 2026
Sida:
Sök jobbet här
We are looking for a Senior Java Backend Engineer (C12) in Belfast to join the core engineering team building Vendor... or interest in Full Stack development with React/TypeScript is a strong plus, enabling end-to-end feature ownership from backend...
Företag: Citigroup
Stad: Belfast
Datum: 07 Nov 2026
Sida:
Sök jobbet här
Senior Data Engineer II - Real Time Data Engineering- Java
. For everyone, everywhere. More about and . Job Description We are looking for a passionate Senior Data Engineer II to join our Treasury Global Liquidity team. In this role, you will help design and build the... with us. So if you have some of those listed below and are eager to learn more we do want to hear from you! We are looking for an engineer proficient with JAVA...
Företag: Wise
Stad: London
Datum: 12 Nov 2026
Sida:
Sök jobbet här
Senior Lead Software Engineer - Java / AWM
libraries, test harnesses or evaluation tools that improve team delivery and quality. Full-stack web or cloud-native...Job Category: Software Engineering Job Description: If you are an experienced engineer who enjoys building, solving...
Stad: London
Datum: 05 Nov 2026
Sida:
Sök jobbet här
Senior Software Engineer - Java - Engine by Starling
for good. As a Senior Engineer you will: Have the opportunity to lead projects or functional areas/domains within the Engine..., regardless of what their primary tech stack may be. Hear more from the team in some case studies, below, and our work...
Företag: Starling Bank
Stad: London
Datum: 29 Oct 2026
Sida:
Sök jobbet här
Sida 1 - Nästa sida
