HPC Project within the Joint Design Office (JDO). The Valve Engineer is responsible for: Undertaking technical.... Coordination Responsibilities The Valve Engineer will also be responsible for coordinating valve related activities within the JDO...
-negotiable). Responsibilities: Responsible for Valves design to size converter valve and cooling plant for tender and project... definition (System design, Valve Converter Mechanical, Main Scheme, Layout, Commercial); Ability to make independent decisions...
System. As a Project Engineer you will drive consistent design practices, common global processes for projects implementation.... What we offer: · Working in an international team which is part of global Engineering HVDC Centre of Excellence within Grid Integration based...
are designed to fit a wide range of industry-common valve cavities. Our employees enjoy a fast-paced and challenging work..., we develop, produce, and distribute our components and system solutions in over 80 countries. Job Description The Senior...
are designed to fit a wide range of industry-common valve cavities. Our employees enjoy a fast-paced and challenging work..., we develop, produce, and distribute our components and system solutions in over 80 countries. Job Description As a Senior...
are designed to fit a wide range of industry-common valve cavities. Our employees enjoy a fast-paced and challenging work..., we develop, produce, and distribute our components and system solutions in over 80 countries. Job Description As a Cycle...
role in supporting all areas of Production and the Mould Shop. In this role, you will be responsible for maintaining... quality system requirements, escalate quality-related issues where appropriate and maintain high standards of housekeeping...
We are the people who give possibilities purpose BD is one of the largest global medical technology companies in the... adoption of our portfolio of products used in Transcatheter Aortic Valve Implantation (TAVI) procedures. As a member...
experts responsible for ensuring HVDC converter valves are designed safely, efficiently, and reliably. You don't just create...' needs into the definition of a system, its architecture and design through an iterative process that results in an effective...
