. Reporting to their assigned Project/Delivery Lead, the Technical Lead will primarily be responsible for working with Clients... to define, design a solution which meets the criteria outlined in their Statement of Work. Requirements Lead Operational...
for you. Reporting to their assigned Project/Delivery Lead, the Technical Lead will primarily be responsible for working with Clients... to define, design a solution which meets the criteria outlined in their Statement of Work. Requirements Lead Operational Team...
. Job Description Key Responsibilities Lead the day-to-day technical delivery of engagements, acting as the primary point of contact... into functional technical solutions and lead the hands-on implementation of Dynamics 365 CE and Power Platform components. Contribute...
transformation journeys. This is more than a delivery role. You'll work closely with clients and project teams to design..., and mentoring, with clear pathways to Senior Manager and beyond. Flexible and hybrid working, supporting work-life balance...
us build reliable, scalable and modern digital solutions. This is a hands-on technical leadership role where you'll lead the... with your Engineering Manager, Architects, Product Managers and Delivery Managers, you'll guide technical decisions, coach engineers...
consisting of a Business Analyst, Scrum Master / Project Manager, Solution Architect, Lead Developers (FE and BE), Developers..., and Testers (Manual and Automated). ITG require a talented Lead Front End Developer to work on the development of a range of web...
, propose solutions to business problems and then lead the technical delivery of the chosen design. If you have a background... from you: ServiceNow or other ITSM Toolsets (HP Service Manager, BMC/Remedy, Cherwell, etc.) Web Technologies (XML, HTML, JavaScript, Web...
technical authority and team members to understand, monitor and report project status Assist the project Lead to deliver the... Project Lead to Plan and document project activities with support from Project Owner and Product Architect Identify human...
within established timelines, while adhering to R&D best practices and processes. Lead development project designs and enforce technical... and continue investment in test automation frameworks. Proactively lead and solicit the involvement of other project stakeholders...
