become game-changing technological advances for Wayve. As a Machine Learning Engineer in the team, you will play a key role... budgets. You will work at the intersection of machine learning research, multi-modal modelling, and real-world deployment...
machine learning models and AI-enabled software components Writing clean, tested and documented code using appropriate... to the Level 6 Machine Learning Engineer Apprenticeship qualification. Entry Requirements To apply, you will need...
and deploy AI and ML solutions. Build machine learning, deep learning and computer vision models. Develop solutions using... AI and ML solutions in complex, safety-critical environments. Strong Python development experience. Expertise in Machine...
around learning by doing rather than just passive video watching. For your ML engineer role, you'd be building the AI engine... with you: Ability to apply your machine learning knowledge to solve real product problems. At least seven (7) years of experience...
time on valuable and meaningful things As Lead Engineer, Machine Learning, you own the execution layer... pipelines for large models. Design evaluation systems that measure capability, robustness, safety, and real-world product...
Principal Machine Learning Engineer Location: London, UK (Hybrid) Employment Type: Full-Time Department: Engineering... Principal Machine Learning Engineer About the Company The company is building an AI-native smart assistant designed to help...
efficiency and reliability of our machine learning operations stack. 🧩 What you'll be working on Lead on large-scale data... efficiency of the machine learning and operations stack. 🙌 You should apply if Essential Hands-on experience with ML...
/thermal or cost) You have strong hands-on experience training and iterating on deep learning models in PyTorch, beyond high... with intelligence, precision and natural flow, unlocking meaningful advances in both safety and efficiency. We believe autonomy...
