Engine Component Responsible jobb - Nyajobben.se - Jobb sök
Vart är du på väg?
Lediga Engine Component Responsible jobb
ENGLD | Materials Application Engineer | Gas Turbine Components
across Infosys. Your role The Materials Application Engineering team is responsible for providing Materials support... and apply your technical proficiency to provide technical and expert materials advice across the Engine programmes for design, development...
Företag: Infosys
Stad: Derby
Datum: 16 Aug 2026
Sida:
Sök jobbet här
Aircraft Powerplant - Engine Bay
for the servicing, repair and component changes of GEnx-1B, CFM LEAP-1B (1B27) and CFM56-7 engines within a dedicated engine... LEAP-1B (1B27) and CFM56-7 engines in the engine bay. Carry out engine component changes, strip and build tasks...
Företag: MPI Recruitment
Stad: Luton
Datum: 17 Sep 2026
Sida:
Sök jobbet här
Semi-Skilled / Skilled Fitter
from approved personnel on how to rectify the issue Responsible for reporting all component / machine non-conformances using the... correct assembly of parts e.g. Visual Aids, Standard Operating Procedures, Drawings, Specifications Responsible for the...
Företag: Magellan Aerospace
Stad: Llay, Wrexham
Datum: 06 Oct 2026
Sida:
Sök jobbet här
Skilled CNC Machinist
Responsible for reporting all component / machine non-conformances using the appropriate forms to the Team Leader or Quality... advanced 3, 5 and 6-axis CNC machining centers. The ideal candidate will be responsible for setting up, operating...
Stad: Llay, Wrexham
Datum: 06 Oct 2026
Sida:
Sök jobbet här
Research Associate in Ethereum
Security (S3) Research Group led by Dr. Lucas Cordeiro. You will be responsible for: Extending ESBMC's Python frontend... to model check the Ethereum consensus specification's reference implementation, including the fork choice component Designing...
Företag: University of Manchester
Stad: Manchester
Datum: 03 Oct 2026
Sida:
Sök jobbet här
Stad: Manchester
Datum: 03 Oct 2026
Sida:
Sök jobbet här
E2 Test Engineer - Business Banking
, reliability, and resilience of customer-facing digital solutions. This role is responsible for driving effective testing practices... engineering practices. You'll design and implement effective test strategies across component, integration, system and end-to-end...
Företag: Nationwide
Stad: Swindon
Datum: 02 Oct 2026
Sida:
Sök jobbet här
GenAI Engineering Lead & Systems Designer
, with responsibility for designing detailed component, API, integration, and sequence-level architectures that enable the... successful adoption of GenAI and Agentic AI technologies. Responsible AI, governance, security and risk management are key expectations...
Företag: Nationwide
Stad: London
Datum: 02 Oct 2026
Sida:
Sök jobbet här
Composite Technical Authority - Technology
development projects with particular focus on Engine and Rotative structures. The Technical Authority will be responsible... 16,000 employees across 32 manufacturing sites in 12 countries we serve over 90% of the world's aircraft and engine manufacturers...
Företag: GKN Aerospace
Stad: Bristol Area
Datum: 30 Sep 2026
Sida:
Sök jobbet här
Publication Change Engineer
instructions in engine manuals, establishing the reason for change, affected manual tasks and engine or component applicability... – Gas Turbine Engine Manuals Job Description Summary The Publication Change Engineer supports the revision and upissue...
Företag: Quest Global
Stad: Derby
Datum: 30 Sep 2026
Sida:
Sök jobbet här
Sida 1 - Nästa sida
