Country: Associate
As a Technical Lead (Systems Engineering) you'll provide technical leadership on a major Royal Navy simulation... to develop, integrate and deliver complex technical solutions. Key Responsibilities Lead the delivery of systems engineering...
while you drift away from engineering. You’ll lead a team of developers, set technical direction and own the quality of what the squad...Want to lead a team without giving up the code? We’re looking for a Tech Lead to head up our Capability squad...
looking for a Technical Lead, Agentic Commerce Engineering to join our ever-evolving agentic commerce engineering team and help shape the.... As Technical Lead in Agentic Commerce Engineering, you will help define and build that infrastructure. This is a hands-on technical...
engineering. This is an individual contributor role where you will lead through the quality of your thinking and your engineering... secure, well-documented APIs and data delivery services for institutional financial clients. Lead technical direction...
cluster. Balfour Beatty is seeking a dynamic Buildings Regulation - Technical Lead to contribute to the Net Zero Teesside... Technical Lead - Building Safety Act As the Balfour Beatty Technical Lead, you will act as the organisation's Designated...
consistently. As Engineering Technical Lead, you'll be responsible for: Help us to build standards and drive a whole team...-on software development experience, operating at Senior Engineer or Technical Lead level Strong commercial experience with .NET...
lead the technical direction of your pod, make architectural decisions, unblock your teammates, and set the standard..., and prioritization within your pod, working closely with your Product Lead to balance technical quality with delivery speed Remove...
Job Description Summary Are you passionate about leading technical projects and driving innovation in control systems... Lead! In this dynamic role, you will be at the forefront of designing and implementing control systems, acting as a bridge...
Systems Engineer - Technical Capability Lead - Porton Down (SP4) - Permanent - Full Time Salary £50,000 - £80,000 DOE... Significant experience in systems engineering, systems integration, test and evaluation, or a related technical discipline...
Job Description Summary As a Test Systems Technical Lead, you will be responsible for the technical direction... Act as the engineering interface to Program Management on test systems topics, clearly articulating technical direction...
