Country: Distributed Network Engineer
Our client, a leading entity in the defence and security manufacturing sector, is looking for an Optical Assembly Build... Technician to join their dynamic new team in Farnborough. This full-time, permanent role offers an exciting opportunity to work...
Job Title: Optical Assembly Build Technician Location: Farnborough, England, United Kingdom Role Type: Permanent... to ground-breaking innovations our mission is to empower and protect lives. Join us as an Optical Assembly Build Technician...
? Join a successful and growing business where you will build specialist electronic products from start to finish within a small, friendly team... Technician opportunity offers: Permanent employment and a 35-hour working week A 4.00pm finish Monday to Thursday...
or manufacturing of electro-mechanical devices. Experience of mechanical assembly and ideally integration of optical assembly. Strong...This engineering company build low-to-medium volume electro-mechanical products used in the aviation and defence...
assembly, impeller fitting, seal installation and final pump build. Interpret engineering drawings, assembly instructions..., tolerances and alignment What We're Looking For Time-served Mechanical Fitter, Mechanical Assembly Technician, or equivalent...
an experienced Production Technician to augment our current Production Team in the electro-mechanical assembly and test of a variety... of infrared thermal imaging related products. Production involves job or batch quantities and can range from cable assembly...
off shift pattern. As a Manufacturing Technician, you will join our Operations team and have the opportunity to build... Technician's to join our team. The Radar and Advanced Targeting line of business, based in Edinburgh, is uniquely positioned...
electrical assembly such as solder wires, tags and components to component boards or terminals Build and test electro/mechanical... assembly's which include bearing fitting, measurement of shaft radial and end play, assembly and alignment of optical...
and maintain wiring diagrams, assembly instructions, build records, bills of materials and other technical documentation. Carry...Job Description Electronics Technician Wotton under Edge Up to £34,000 Renishaw’s Encoder Products Division...
In Basingstoke. As an Application Technician, you will: • Support engineers with the development, assembly, testing, and validation... discipline, or equivalent practical experience. • Probable experience within optical fibre cable assembly or a related...
