Country: Machine Setter
Tech Support / Process Engineer (CNC) Cheltenham £45,000 – £55,000 + Training + Progression + International Travel... + Company Vehicle Are you an Applications or Process Engineer looking to use your technical knowledge to train...
requires a time served CNC Tech/process Engineer with a proven track record and experience in machining aluminium diecast... components on high speed 5 axis machines. Reporting directly to Assembly Engineering Manager, the CNC Tech/process Engineer...
on the shift, the CNC Tech/process Engineer is required to be able to work off their own initiative whilst also liaising... with Production, Quality and Maintenance to respond to any issues that affect CNC operation. The CNC Technical Engineer...
CNC Turner | CNC Machinist | CNC Lathe Operator | Precision Engineer | Aerospace CNC Turner Yeovil, Somerset... Machinist, CNC Lathe Operator, Precision Engineer, or Aerospace CNC Turner role in Yeovil, or contact Stacie at Acorn...
