Country: Machine Setter
Job Title: Integration Design Engineer - Electrical Location: Portsmouth Naval Base, Onsite Salary: Up... at BAE Systems could take you. What you will be doing: In this role, you will provide electrical design and integration...
Job Title: Integration Design Engineer – Electrical Location: Portsmouth Naval Base, Onsite Salary: Up... at BAE Systems could take you. What you will be doing: In this role, you will provide electrical design and integration...
. This is a hands-on role focused on mechanical design and integration, working across electrical systems, software, and control..., and fault recovery. Plan iterative hardware development through focused prototypes, staged integration, design reviews...
: £60,000 – £75,000 (depending on experience) Employment type: Permanent Purpose of the Role As a Principal or Associate Electrical Engineer... overseeing the output of others. You'll have the opportunity to influence electrical design strategies, challenge conventional...
to come. As a Graduate Electrical Design Engineer, you'll join our 2027 Early Careers programme and gain hands-on experience... needed for a successful career. In this role, you'll join one of our Balfour Beatty Power T&D teams as a Graduate Electrical Design Engineer, based...
Job Description Electrical Design Engineer Bristol / Hybrid An excellent opportunity has arisen for a Test... Facility Design (TFD) Electrical Design Engineer to join our team in Bristol. The Bristol Facility Design engineering team...
Design Engineer Coventry We're looking for a talented Electrical Design Engineer to join our team. This is a fantastic... Engineering team. What you will be doing: As an Electrical Design Engineer, you'll play a key role in delivering high-quality...
Electrical Systems Design Engineer Permanent Full-Time Salary – Circa £42,000 DOE Location – Remote or Hybrid... Electrical Systems Design Engineer. Working across the full project lifecycle, from initial concept and schematic design through...
Electrical Design Engineer - Building Services Cambridge (hybrid working) £45,000 to £55,000 The opportunity... A medium sized and well-established building services consultancy is looking for an Electrical Design Engineer to join its...
