Control Automation System Engineer, you will be responsible to lead the requirement, design, implementation, and development... control system of the HVDC Control & Protection system this includes network & Cybersecurity design Lead the configuration...
Software Controls Systems Engineer to join our control system software team. The role involves developing, commissioning... and supporting control system software integration for industrial automation projects across multiple sectors. You will collaborate...
successful Senior Control Automation System Engineer, you will focus on: NPI, ITO, OTR and Product Care All aspects of HVDC Control..., design, implementation, and development of digital control system of the HVDC Control & Protection system. Roles...
🚀 Join our Team as a Senior Control Systems Engineer Location: Billingham or Worksop Hours: 37.5hrs per week... automation? We're Actemium Automation Teesside - part of the global VINCI Group - and we're on the lookout for a Senior Control...
that defines the hardware, system configuration and network technical requirements of an HVDC control system as part of a project...) files for system integration. Knowledge of interlocking principles used in substation automation systems...
in substation automation, SCADA, RTU, or control systems engineering, including system integration and testing. Technical Knowledge...-level control and automation solutions that transform customer needs into integrated systems for substations! In this role...
. We are looking for a Lead Control Automation Hardware Engineer with significant experience in substation panel design, protection hardware..., and Communication systems. As the Lead Control Automation Hardware Engineer, you will be responsible for developing robust, standards...
automation and DP platforms within the NPI framework Develop control logic, algorithms, and system architectures to meet...Job Description Summary We are looking for a talented and motivated Controls & Automation Engineer to join our New...
on electrical power system. A minimum of 10+ years as Lead Engineer or equivalent role with relevant experience in control... (LPO) requires experienced Protection, Control & Automation Lead to take overall technical lead of Control, Protection...
