Job Description Mechanical Design Engineer- Electrical Machines Full time Derby/ Bristol/Solihull/Hybrid... for next-generation aircraft. We are seeking a Mechanical Design Engineer with experience in electrical propulsion, energy storage...
conjunction with Electrical and Mechanical Engineers and collaborate with Customers and Project Management, Sourcing... of large electrical machines. Leading to carry out detailed analytical / finite element analysis of machines...
Description CGEN Engineering Ltd is seeking a Senior Electrical Machines Engineer to support the development of its... permanent magnet generator technology is intended to improve how large electrical machines are designed, manufactured...
an experienced Electrical Design Engineer looking to take on greater technical ownership or a Senior Engineer seeking more complex... Engineer - The Role: From electrical system design and compliance through to component selection and technical documentation...
and winding machines for the electrical, energy, and oil & gas industries. Recently acquired by Tokamak Energy to accelerate... two Mechanical Design Engineers to join our engineering team in Leicester. One appointment is likely to suit...
Mechanical Design Engineer Brixworth Up to £510 per day Inside IR35 NX Design Engineer is required to work... and electrical vehicle systems. Experience in detailed mechanical component design and electrical system packaging. Deeper...
Senior Mechanical Design Engineer – SolidWorks Permanent Full-Time Salary – Circa £50,000 DOE Location – Office.... As a Senior Mechanical Design Engineer, you will be responsible for the design, development, testing, and delivery of innovative...
industrialisation of HTS products. About the Role We are seeking an experienced Mechanical Design Engineer to join our team working.... Ridgway Machines - Manufacturing equipment for the superconducting, electrical and wider energy sectors, enabling the rapid...
industrialisation of HTS products. About the Role We are seeking an experienced Mechanical Design Engineer to join our team working... Machines - Manufacturing equipment for the superconducting, electrical and wider energy sectors, enabling the rapid...
: · Detailed mechanical design of new machines from cradle to grave · Re-engineer existing machinery to enhance design...You’re a Mechanical Engineer first and a Design Engineer second. As our Mechanical Design Engineer, you’ll work on R...
