Job Description Mechanical Design Engineer- Electrical Machines Full time Derby/ Bristol/Solihull/Hybrid... for next-generation aircraft. We are seeking a Mechanical Design Engineer with experience in electrical propulsion, energy storage...
Job Description Manufacturing Services Engineer Full time Bristol An excellent opportunity has arisen... for a Manufacturing Services Engineer to join our team in Bristol to co-ordinate the key maintenance activities within our facility...
propulsion systems. It focuses on computational analysis, aerothermal performance, and cross-disciplinary design. If you're...Job Description Radio Frequency Engineer - Aerothermal Full time - Hybrid Bristol When you join as a Radio...
. We are now looking for a Performance Simulation Engineer to join our team! Role Purpose: To design and analyse components and systems for relevant... and calibrate 1D engine models to carry out investigations on performance sensitivities of hardware design parameters Perform...
Are you an experienced aerodynamicist or flight performance engineer looking to play a defining role in the development... Performance & Aerodynamics Engineer, you will lead aerodynamic modelling, missile performance analysis, and trajectory simulation...
An exciting opportunity has arisen for a talented, hands-on Mechanical Design Engineer to join a growing and innovative... successful candidate's security clearance process will be sponsored by the employer. If you're a Mechanical Design Engineer who enjoys...
Mechanical Design Engineer Location: Newark Salary: £28,000 – £35,000 DOE Job Type: Full-time | Permanent... Overview An exciting opportunity has arisen for a Mechanical Design Engineer to join a growing building services engineering...
's existence questioned, and every manufacturing step scrutinised. We're looking for a talented Senior Mechanical Engineer to own... mechanical design with thermal modelling to understand system behaviour, make design decisions and then turn those decisions...
Description Amazon Web Services is seeking a Mechanical Design Engineer who can perform design engineering activities... our focus on quality, speed, and cost. If you can design a mechanical system, have an understanding of the critical equipment...
Lead Mechanical Design Engineer Location: Salary: Competitive Overview: Are you an experienced Lead Design... Mechanical & Electrical Design Engineer, you will lead the mechanical and electrical engineering function, providing technical...
