RINA is looking for a highly experienced Lead Design Engineer to join its growing Power Systems Consulting team..., delivering complex Substation Design and Power Systems Studies engagements for large power and electricity corporations, DNOs...
Electrical Design Engineer – Power Systems Building Services Engineering Solihull Area / West Midlands Salary up... for you! What is required from the successful Electrical Engineer? A building services background or proven experience in power systems. Able to use...
Job Title: Senior Engineer – Electrical Engineering (Power) Location: Barrow-In-Furness (Hybrid – minimum of 3 days... that the TA (Technical Authority) merge joint LfE (Learning from Experience) into the EPS (Electrical Power System) design...
Job Title: Senior Engineer - Electrical Engineering (Power) Location: Barrow-In-Furness (Hybrid - minimum of 3 days... that the TA (Technical Authority) merge joint LfE (Learning from Experience) into the EPS (Electrical Power System) design...
Electrical and Control System Design Engineer Opportunities - Warrington We're looking for experienced Electrical... in either: Electrical design engineering (small power, lighting, earthing) OR Programmable Electronic System (PES)-based control system...
of AtkinsRéalis is seeking a Senior Power System Studies Engineer with extensive offshore wind or renewables experience to lead grid...Job Description Overview Let's secure the future of energy. The Power Energy Systems (PES) Practice...
Consultant: Julie Linegar Senior Power Systems Engineer We are currently recruiting for a Senior Power Systems engineer...’s in electrical engineering, or a related field, and have a good understanding of electrical engineering theory and power systems...
degrees in Electrical Engineering /Electrical Power Systems or similar. Preferably you will be a Chartered Engineer or working... assessment, supply and system resilience, utilities consultancy and sustainable electrical engineering design. Whether...
throughout the UK and Ireland. Here's what you'll do: Support the delivery of electrical design through power system studies... understanding of power electronics and control systems related to renewable technologies Exceptional levels of written and oral...
