Country: Structural Engineer
and Protection System Application Engineer you will report to the Control and Protection System Application Manager. The... and an innovative approach. As a Control and Protection Systems Application Engineer, you will be expected to study on the existing...
’s Grid Systems Integration business is looking for an experienced Senior Engineer - HVDC Control & Protection System... Application to join the HVDC NPI team. This is a senior technical role for an engineer who can act as a trusted consultant...
Lead Control & Protection System Engineer, you will report to the Control System Application Manager. You will be part... and leading team with an excellent technical background. Experienced in Protection & Control system design application...
Job Description Summary The Power System Engineer will have prior knowledge and expertise in Electrical Protection.... Knowledge of protection and control system design, testing, and commissioning for synchronous machines. Experience...
that support a smarter and more resilient future. We're looking for an Application Engineer – Switchgear Controls & Digital... as a technical champion for switchgear controls, protection, and digital systems.Contribute to technical documentation...
technical capability associated with the design and/or application of power system protection. Preference will be given...: Scarlet Wilson Protection & Control Engineer Duration: 6 months Rate: £80 - £100 p/h (inside IR35) Our client...
Senior Design Engineer - Protection and Control Leeds, United Kingdom (Hybrid, Office, Site) Permanent Competitive...) is highly desirable. Experience: Extensive experience in electrical protection and control system design, Substation Automation...
Engineer, you will design of a range of Technical Protection & Control solutions for EHV substation projects including both AIS... as required. You will: Produce a comprehensive suite of protection and control system design drawings for 11kV up to and including 132kV systems...
projects that make a difference. As a Protection & Control Engineer, you'll have the opportunity to tackle complex engineering... see how your experience aligns to this role and other opportunities within the team.. A little more about your role… As a Protection...
Upgrade'. You'll spearhead design activity and hold responsibility for developing protection and control system designs... Panels, and RTU/SCADA interfaces Prepare Protection Relay Settings philosophy and coordinate with system studies...
