architect, you will be responsible for the provision of architectural services associated with process industry construction... of opportunity and the chance to shape a career as unique as you. A little more about the role... As a manufacturing process...
Telespazio UK are seeking a Senior Software Engineer/Architect to join their Ground Software Systems group. Overview... in a senior capacity with software development and architectural responsibilities you will be developing new web-based apps...
ISO 9001:2008 certified Cwmbran Manufacturing Devices & Panels ## What you’ll do: The Product Architect..., the Product Architect ensures that products are scalable, secure, compliant, cost-effective, and aligned with customer...
process itself. As an Azure Solution Architect, you will be accountable for defining the technical vision and target-state.../Must have: Proven experience in Senior Cloud/Solution Architect roles, with a strong focus on designing and implementing AI-driven...
how and where it matters most. Connect to your opportunity Senior Manager, Media Architect As a Senior Manager, you will hold... patterns and AI/ML services. Proven track record (projects or in a lead role) in an AWS Technical Architect or Lead Engineer...
from the ground up, making high-level decisions about each stage of the process and directing a team of engineers to build the... with meaningful careers! ROLE SUMMARY: As the Application Architect you will work with the Solution Architect of World-Check...
delivering projects across sectors including Education, Healthcare, Defence, Energy, Commercial, and Residential. As a Senior... Architect, you will have the opportunity to lead high-profile projects from concept through to completion, working...
on obtaining the relevant level of clearance. If this is necessary, it will be discussed with you at interview. The vetting process...Job Description Overview AtkinsRéalis are looking to recruit an innovative and experienced Project or Senior...
